Helper class picker not working due to error in CSEndUser skin (included cs-icons stylesheet)
I found this webpage that describes the exact problem we are facing: https://collaborate.pega.com/question/unable-view-list-helper-classes-pega-731
The file that is causing us the problem is a different file within a different platform version but the same issue remains, a broken helper class picker caused by a mistake in a stylesheet that is marked as final.
Pega platform 8.2.5
Pega Customer Service, v: 8
Pega Healthcare framework: v: 8
Skin CSEnduser within RS: PegaAppCA:08-02-02
Within that skin, the following style is included (as well as others - but the issue was isolated to this file):
- cs-icons (of RS: CPM:08-02-01)
- The bottom part of the file is incorrectly commented out.
The workaround, private edit, is to add the comment in the proper location and remove the */ at the end of the file. However, as it is a private edit on a final rule, it cannot be checked in.
Is there another way to fix this or is a GCS support ticket required?
The fix described below:
Original file:
Note: Below icons are pointed to Platform font icons
.pcs-ssaicon1:before {
content: "\61";
Pega platform 8.2.5
Original file:
content: "\61";
Fix:
(Description)By adding the */ after the note, and removing the */ at the bottom of the file, the helper class picker is properly showing all the helper classes available to the developer.
Resulting view of file:
content: "\61";
