Blue Cross Blue Shield of Michigan Inc
Last activity: 3 May 2020 10:56 EDT
Multi Select not populating
I am trying to populate multi-select dropdown from clipboard list but it's not populating and shows "No results found". I can see values in clipboard list. Thanks for your help.
FR
Can this be helpful maybe: https://collaborate.pega.com/question/cascading-drop-down
Updated: 14 Jun 2021 7:38 EDT
Where are you setting the values in the pagelist? Is it in the pre-processing Data Transform or Activity?
Yes, setting the values to pagelist. I used pre-processing data transform.
Did you find any errors or exceptions in the Tracer for the stream rules?
No errors or exceptions
Seems like all configurations are correct, Did you define clipboard page in pages and classes of the section rule?
Can you try checking if the clipboard page is getting populated before the section(in which Multi Select is there) renders
Yes, I confirmed page is getting populated before the section.
I have tried the similar use case which you have mentioned, but able to see the values. Could you please check if all the properties are given correctly.
Do you have steps or screenprints you used, I can try to use the same steps.?
PFB Screenshots
Thanks Yerrh. Where did you call the data transform?
Also , we are using platform 8.1.7
I have implemented this in 8.3.0
Thanks Yerrh. Just to add here, I am using embeded list. Can you try with embeded list.? Thanks
I added a table on same page and assigned the same list to table data source and I can see the values in table. But this list is not populating in multi-select dropdown.
