Question on globally optimized strategy in Customer Decision Hub
I understand the concept of globally optimized strategy. But how to create a globally optimized strategy? Will pega create once I click compile button? Or should I do it manually. Please clarify.
Example:
In the below article, I have seen the NBA strategy. But how does the OptimizedNBA strategy created? Can any one clarify on this.
To create a Globally Optimized Strategy, user has to do it manually following this guide: https://community.pega.com/sites/default/files/help_v84/procomhelpmain.htm#rule-/rule-decision-/rule-decision-strategy/strat-opt-setting-global-opt-tsk.htm
It is a separate flavor of the regular strategy rule and has to be included in your flow of execution (e.g. Data Flow) manually as if it were a regular NBA strategy.
Note: Globally Optimized Strategy is still a beta feature as of 8.4 - it gives the best performance improvements from Strategy, but also watch out for any caveats there.
Hope this helps.
