ANZ Banking Group Ltd
Last activity: 3 May 2020 6:47 EDT
pyLabel is not allowing the more than 64 characters
My application was built on PEGA 7.1.7. and CPM framework. we are using pyLabel property which is belongs to CPMFS ruleset. This property is not allowing the 64 characters and to resolve this issue we have increased character length from 64 to 256 in data base table. after making the db changes i have done below task's.
1) clear restart.
2) save and test connectivity for class.
3) save and test connectivity for db table rule instance.
still pyLabel is not allowing the more than 64 characters. when i am trying to increase the character size in property advanced it is showing the bellow error.
Error Message: Maximum Length - Because property is exposed in a database column. 128 has been changed to 64 conform to base property definition.
I have verified below link also. it did not help me.
https://collaborate.pega.com/question/pylabel-too-long-maximum-length-allowed-64
Kindly provide the solution to resolve this issue.
Thanks & Regards,
Rama Krishna
Hi Rama
Can you go through the below posts , they talk about the same issue and has been resolved by a local change :
https://collaborate.pega.com/question/pylabel-property-increase-max-length-128
https://community.pega.com/support/support-articles/pylabel-work-class-not-allowing-more-64-characters
