Optimizing more than property in parallel?
is there a way to optimize more properties of one class in parallel?
Regards
Uwe
Regards
Uwe
If all those properties belong to a data class, you can go to Data explorer and click on the class , go to records tab.
Click on add Source.This will create new data table and will optimize all the properties available in that class.
We can choose the properties we want to optimize in the modal dialog that is launched on clicking the create data storage link in the records tab.
I don't want to create a new table. the class, table, etc. exists. now I need a couple of existing properties optimized for a huge table.
regards
uwe
Is that a data class ? If so , you can go to the records tab in the data explorer.Click on Actions menu>> Edit Columns . Enter the properties that are already created in the fields and click on submit.
This will automatically optimize the properties without creating a new table.
Vijaya
Pega is showing me the message "Data records cannot be configured for cases." in the records tab. What's going wrong?
Regards
Uwe
For Case types, Data records cannot be configured. They are configurable only for data classes.I don't think there is a way OOTB in pega to optimize multiple properties in a single go for Work Classes.
We can achieve this for Data classes using Data explorer wizard.
Vijaya
