Roles
Is it possible to create individual roles based on company identified skills?
Yes, it's possible to create multiple roles. Could you please give more details about the requirement.
Thanks for reply!
The idea is to collect relevant company skills and map them to specific roles.
Example 1: Skills: english A1, C++ knowledge, controlling Know-How etc. is assigned to Role A.
Example 2: Skills: german a2, Java knowledge, marketing Know-How etc. is assigned to Role B.
The requirement would to import this relevant Skills from SAP success factors (prior SAP HR) and map them to defined roles. If assigned skills to a person changes the system have to recognize the change and check if the person have to switch the role --> additionallly get other rights.
You could use Skills in Pega as well. Allow you to route work and control assignments based on these.
Any specific reasons you'd like to go for Roles?
The requirement would to import this relevant Skills from SAP success factors (prior SAP HR) and map them to defined roles --> do you support this required interface towards SAP success factors?
Skills can be associated with the users, not with the access roles.
Please find the below articles for more details.
https://community.pega.com/sites/default/files/help_v84/procomhelpmain.htm#definitions/s/skill.htm
