UST Global
Last activity: 28 Feb 2020 16:59 EST
overlapping search results
There is table layout inside a dynamic layout in a section. That section is being called in another section. But when I run the application and enter the details and the customer search table executes, it tends to overlap on sideways when I increase my screen resolution above 100%.
The business requirement is that it should not overlap at least till the resolution is 140%.
I have tried many different things like changing the layout format and trying everything in presentation tabs including changing to legacy system. Does anyone has a solution for it.
***Edited by Moderator Marissa to change from Discussion to Question type; update platform capability tags****
