Screen layout overlap with header
Recently I just upgraded from Pega 7 to Pega 8.6. Unfortunately I found a portal that's overlapping with the header. The layout below is harness with screen layout header left. At first, I thought it caused by the layout content, but nothing happen when I make the layout content invisible. Then I tried to customize using inspect element, worked but when I put it on inline style it doesn't work.
I also manage to tried this solution but nothing worked too. https://collaborate.pega.com/question/unable-add-header-screen-layout. Is there any suggestion to make it not overlap with below content and menu? Thanks in advance
