BIX Extraction(Redshift)
Is a direct BIX Extraction (work table to redshift) supported to a target redshift database ?
BIX is used to read data from PEGA OOTB table's put the data in CSV , XML or can generate SQL queries to inject the data into another relational data base. So for your requirement you should first check if RedShift is relational data or not [ i guess it is, based on my research] then extract the data using BIX. More information on BIX can be found in below links.
https://community.pega.com/system/files/media/pdf/2018-07/BIX%207.4%20User%20Guide.pdf
https://community.pega.com/knowledgebase/documents/bix-81-user-guide
Please mark the post useful or correct in case this reply helps you.
Rajesh
