Independent
Last activity: 4 Jan 2021 12:57 EST
Federated Case Management (FCM) in Pega 8.3 - What are the rulesets?
I would like to find out what the latest version of FCM is. When I went into Digital Delivery, I can only find the versions for 7.1 and 6.3.1. I am looking into implementing this in 8.3. Are the rulesets included in the base 8.3 installation? If so, what are the names?
***Edited by Moderator Marissa to update SR Details; Product Name & Version***
To confirm what you found on Digital Software Delivery, I see on the Pega Community product page for FCM that FCM 7.1 is the latest release.
Pega Federated Case Management, https://community.pega.com/knowledgebase/products/federated-case-management
Independent
Mary, can you confirm that FCM 7.1 is what we should be installing into Pega 8.3 if FCM capabilities are required?
Thx
Terence
Terence,
You need to wait for a product SME to answer all of your questions. I am not a product SME.
(My uneducated guess would be that an FCM 8 release might need to run on the Pega 8 platform -- considering sync on homogenous releases. But perhaps uniform matching of releases is not needed? I don't know.)
Thanks for your patience in waiting for a product SME to reply here.
-Mary
PEGA-FCM 07-10 Ruleset should be included in your application stack for 8.x version.
And it is not shipped by default with the installation setup. It is a separate RAP.
Ravi,
Many thanks for your rapid response to Terence's question.
Ravi - Can you answer the following:
- Where's the documentation for FCM on Pega 8.x? or is there an article?
- Is the gateway support and required for Pega 8.x to use FCM?
FCMR requires separate Pega-FCM ruleset still requires gateway support.
The below links for FCMR which still hold good for 8.x
Scotiabank
Hi, a quick follow up to the conversation.
On the page at:
There is a broken link in the bottom-most section to what appears to be a topic on "Configuring Pega Web Mashup with the Gateway Configuration Console" -- could you please provide the valid link for that topic?
I have submitted Feedback on the article cited.
The broken link goes to the old Drupal 7 server (as indicated by the URL qualifier community1).
The correct URL is --
I have submitted Feedback on the article cited, https://docs-previous.pega.com/configuring-and-publishing-federated-case-management-repository-data-fcm-712.
Tip: You can report issues like this one by clicking the Feedback (orange) button on the Pega Community page where the problem exists. Your Feedback submission will go directly to the content owner.
Hmmm . . .
I'm now going to submit PCC Feedback reporting the DUP post seen above.
(I edited my first reply. My edit should have updated my post, not duplicated it with the added info.)
My Feedback submission on the PCC Edit Reply problem:
https://community.pega.com/webform/pega_community_feedback/submissions/8271
My Feedback submission on the article broken link:
https://community.pega.com/webform/pega_community_feedback/submissions/8266
Independent
Can we clarify this gateway requirement a bit further?
I saw the following regarding gateway is not longer required for Pega Web Mashup:
I thought FCM makes use of Pega Web Mashup. With that, is the requirement for gateway an FCM specific?
Independent
In Ravi's previous post, a Gateway is still required. However, in the 8.3 Installation Media, the prgateway.war file is not included. We have also tried to download the Mashup 7.1 media, the prgateway.war is also not there.
Where can we get the prgateway.war file?
Independent
SR-D82976 has been opened to track this issue.
Scotiabank
A quick update for those who may not have access to the SR case.
"You will be fine with the combination you are planning on using, PRGateway from 7.1.7 and FCM 7.1.2 on Pega Platform 8.3. I did check and there is a project in place to update FCM to use new Mashup implementation so PRGateway wont be needed in the future. This is being looked at as part of 8.5 but I can’t give you an exact release version yet. I checked patches for FCM 7.1.2 and the one you mentioned was the only one for that product version."
...and...
"Relevant hotfix identified as HFix21361"
Mary Carbonara
I traced HFix-21361 for Pega Federated Case Management 7.1.2 to SA-7765, https://community.pega.com/support/support-articles/pega-fcm-error-application-validation-save-new-application
Scotiabank
Is there any timeline available for FCM 8.X ?
also, if we upgrade to FCM 8.X , Can we continue to connect from applications built on PRPC V6.X and V 7.X versions?
