Identify Duplicates from work objects created within same time frame
I have business case where a listener would read a set of 50 files and create work objects simultaneously. We have a logic to identify duplicates in the process flow where an RDB-List identifies the duplicate Work object list. But when work objects are created within a time gap of few micro seconds, e.g. W-1 and W-2 where W2 is a duplicate of W1, the RDB-List doesn't return W2 as duplicate W1 as W1 is still not committed into DB when W2 duplicate logic is being executed.
Any suggestions on how to handle this scenario?
Thanks for posting your query in PSC !
Are you using Duplicate search Utility shape to identify the duplicate casetypes? If so, have you specified the weighted conditions and the conditions to match accordingly?
Add a persist case step to persist the casetype to the DB and check the behavior.
Thanks.
