CVS Health
Last activity: 22 Dec 2019 16:19 EST
Got an err while integrating with Jenkins from Pega V722
I have followed the below PDN article strictly to setup Jenkins integration using Pega 7.2.2 (Dev env).
I am getting the below err while deploying the code. Attached the settings and the err details too.
Jenkins version:2.209
JDK:1.8.0_121
ANT version: apache-ant-1.10.7
[jenkins] $ cmd.exe /C "ant.bat -file Jenkins-build.xml -DproductVersion=01.01.01 -DproductName=HRServicesRAP exportprops && exit %%ERRORLEVEL%%" 'ant.bat' is not recognized as an internal or external command, operable program or batch file. Build step 'Invoke Ant' marked build as failure Finished: FAILURE
Can any expert in this area help me?
Ravi Kumar.
Likes (3)
ADITYA KORALE Narasimha Reddy Saravana Kumar G -
CVS Health
This is to inform that my issue got resolved after setting up this whole process from fresh and that too this time I have used my personal laptop. Due to firewall or permissions issue from my office laptop, I couldn't succeed earlier and I was seeing all the mentioned issues. Now I am good and I was able to push the code from V722/V8.1 (source) to V722/V8.1(target). Hoping that "prpcserviceutils" file version is not a matter based on my observation. The main cautious piece over here is the proper settings, proper permissions in the laptop and enough speed of the system to run ANT,Jenkins without any delays/timeout issues. Thanks for all the folks who helped me in this regards,
Ravi Kumar
BPM Company
Do you have Ant installed (https://ant.apache.org/)?
CVS Health
Yes I have installed and mentioned the Ant path as a global setting in Jenkins too.
Pega Systems
Refer this : https://community.pega.com/support/support-articles/antbat-not-recognized-command-when-integrating-prpcserviceutils
CVS Health
Thank you Anil for posting this article. I have gone through it and I did cross check at my end on those plugins mentioned. But still no luck.
EAI Systems
SG
Hi Ravi Kumar
Refer the attached document for defining ANT_HOME in system variables and Jenkins, i guess this solution resolves your current issue.
Srikanth
CVS Health
Thank you Srikant. The mentioned error is gone and I got a new err after following your document. Here is the err and my Jenkins settings for Pega V8.3 (localhost). Please check and correct me where I went wrong.
-processInstances: [echo] Performing export on multiple instance(s) [pega:echoargline] arg line : -action export -propFileDir C:\Users\rpisupat\Documents\JenkinsIntegPega\Pega\prpcServiceUtils_v83\scripts\utils/generated -poolSize ${prpcserviceutils.pool.size} -requestTimeOut ${prpcserviceutils.request.timeout} -tempDir C:\Windows\TEMP\/PegaInstallTemp-20-December-2019-13.49.04 -artifactsDir C:\Users\rpisupat\Documents\JenkinsIntegPega\workspace\PegaCodeDeployment -processFailStrategy FAIL_PROCESS_ON_SINGLE_SYSTEM_FAILURE [echo] Reading connection information from C:\Users\rpisupat\Documents\JenkinsIntegPega\workspace\PegaCodeDeployment\jenkins-PegaCodeDeployment-24_export.properties BUILD FAILED C:\Users\rpisupat\Documents\JenkinsIntegPega\Pega\prpcServiceUtils_v83\scripts\utils\prpcserviceutilsWrapper.xml:179: Connection Property file C:\Users\rpisupat\Documents\JenkinsIntegPega\workspace\PegaCodeDeployment\jenkins-PegaCodeDeployment-24_export.properties is not a valid file Total time: 2 seconds Exiting with Error Build step 'Execute Windows batch command' marked build as failure Finished: FAILURE
EAI Systems
SG
Hi Ravi Kumar,
Refer the below article where i have clearly documented E2E process.
Let me know if you have any other issues on top of this.
Srikanth
CVS Health
Perfect Srikanth!
One question is like can I use V83 for the same exercise you mentioned in the doc? Will it work? Pls let me know.
Ravi Kumar
CVS Health
Hi Srikanth,
I have followed the article and I was successful in integrating Jenkins with V83 (localhost) and I saw build was successful. But I checked the target:localhost system and the code is not deployed though build was successful from the console log. In my case both source and target are V83 localhost instance only. Please let me know on why I didn't see the code deployed in target env.
Hi Srikanth,
[EnvInject] - Injecting as environment variables the properties content ImportExistingInstance=override ARTIFACTS_DIR=C:/Users/rpisupat/Documents/JenkinsIntegPega [EnvInject] - Variables injected successfully. [jenkins] $ cmd.exe /C "C:\Users\rpisupat\Documents\JenkinsIntegPega\Ant\apache-ant-1.10.7\bin\ant.bat -file Jenkins-build.xml -DapplicationVersion=01.01.01 -DproductVersion=01.01.01 -DTargetHost=https://localhost:8080 -DTargetPassword=rules -DproductName=HRServicesRAP -DapplicationName=HRServices -DTargetUser=HRAdmin exportprops && exit %%ERRORLEVEL%%"
Buildfile: C:\Users\rpisupat\Documents\JenkinsIntegPega\Pega\prpcServiceUtils_v83\scripts\samples\jenkins\Jenkins-build.xml
exportprops:
[propertyfile] Creating new property file: C:\Users\rpisupat\Documents\JenkinsIntegPega\Pega\prpcServiceUtils_v83\scripts\utils\jenkins-PegaV83ExportImportRAP-6_export.properties
BUILD SUCCESSFUL
Total time: 15 seconds
[PegaV83ExportImportRAP] $ cmd /c call C:\Windows\TEMP\jenkins6038166514587297634.bat
C:\Users\rpisupat\Documents\JenkinsIntegPega\workspace\PegaV83ExportImportRAP>C:\Users\rpisupat\Documents\JenkinsIntegPega\Pega\prpcServiceUtils_v83\scripts\utils\prpcServiceUtils.bat export --connPropFile C:\Users\rpisupat\Documents\JenkinsIntegPega\workspace\PegaV83ExportImportRAP\jenkins-PegaV83ExportImportRAP-6_export.properties --artifactsDir C:\Users\rpisupat\Documents\JenkinsIntegPega\workspace\PegaV83ExportImportRAP
[jenkins] $ cmd.exe /C "C:\Users\rpisupat\Documents\JenkinsIntegPega\Ant\apache-ant-1.10.7\bin\ant.bat -file Jenkins-build.xml -DapplicationVersion=01.01.01 -DproductVersion=01.01.01 -DTargetHost=https://localhost:8080 -DTargetPassword=rules -DproductName=HRServicesRAP -DapplicationName=HRServices -DTargetUser=HRAdmin importprops && exit %%ERRORLEVEL%%"
importprops:
[copy] Copying 1 file to C:\Users\rpisupat\Documents\JenkinsIntegPega\Pega\prpcServiceUtils_v83\destination
[propertyfile] Creating new property file: C:\Users\rpisupat\Documents\JenkinsIntegPega\Pega\prpcServiceUtils_v83\scripts\utils\jenkins-PegaV83ExportImportRAP-6_import.properties
BUILD SUCCESSFUL
Total time: 2 minutes 57 seconds
[PegaV83ExportImportRAP] $ cmd /c call C:\Windows\TEMP\jenkins2637485643329802037.bat
Finished: SUCCESS
EAI Systems
SG
Hi Ravi Kumar,
1. Might be both Source and Target env are same, can you try with having both source and target are different.
2.Can you share build.xml file,export and import property files generated by successful build for further debugging.
Srikanth
CVS Health
Hi Srikanth,
I am good to go now. As I mentioned my final reply to this post, all issues are related to my office laptop's permissions issue. Same exercise working in my personal laptop and no issues so far. It is the time for me to play on setting the Pipelines and the scheduling of the jobs from Jenkins. Lot more work is there to focus :)
Ravi Kumar.
CVS Health
Hi all,
I have followed the below article and changed the settings for my Jenkins integration but still I am getting the issue.
BUILD FAILED
C:\Users\rpisupat\Documents\JenkinsIntegPega\Pega\prpcServiceUtils_v83\scripts\utils\prpcserviceutilsWrapper.xml:179: Connection Property file -Dprpc.service.util.action=export is not a valid file
Total time: 4 seconds
Exiting with Error
Finished: FAILURE
CVS Health
Ravi Kumar
