Same Date and Time format across the entire application
Is there a way to force all the date and DateTime properties to display in the same format everywhere (UI, reports, ...)?
For now, I only see the option of defining the control format we want and choose this control in the UI and reports, but this means that we must manually change the control in every sections and reports, which is very time consuming and we risk to forget some sections.
I'm not fully sure but I don't think you can do this Out-Of-The-Box. What Pega version is it? In theory you will always have the possibility to change the format.
