How to perform validation on the incoming json fields
I'm new to Pega, can you pls give me an example on how to perform validation on the incoming json fields in Pega.
Mani
Mani
To restrict the number of characters, you can specify the min/max characters in the cell properties :
Also, you can create an Edit validate rule and can use in the Property directly which will be specific for that property :
Hope it helps!
Thanks mutha1. I would like to validate all the json fields before getting into any actual steps so I can respond to the invoking app that its not a valid json. FYI, I dont have a UI for this app.
