Virtusa
Last activity: 11 Dec 2019 22:09 EST
Case Search in Developer Portal
Hi ,
With Work Index enabled , we can search case id in designer studio , is there any config/way to enable search for cases in designer studio with other property than case ID ?
Which other property you would like to be searchable in designer studio?
https://community.pega.com/knowledgebase/articles/designer-studio/designer-studio-overview
Virtusa
Hi Susan,
Like with pyStatusWork , say “Resolved-Completed”
BPM Company
Basically, what you want to achieve is related to elasticsearch approach. Essensially, you need to create an instance of Custom Search Properties rule (see in Records Viewer/SysAdmin) where you mention all the properties you want to search on.
Plus, here 2 articles which will help you:
https://collaborate.pega.com/question/elastic-search-alternative-exposing-properties-reporting
https://collaborate.pega.com/question/pega-720-steps-configure-elastic-search
Virtusa
There is already a OOTB custom search property rule which included pyStatusWork , but in designer studio it only gives results for pyID
Did you try with selecting "All Content"? If that is also not working please share screen shot of Search landing page. Also let us know the pega version.
Virtusa
Yes , i have tried All content search also , it gives results only for case id and nothing else , below is the screen of search landing page .
Pega Version : 7.4 PE
Swedbank AB
SE
Hello Adithya,
Customizing the Section "pzSearch" might help you achieve this.
Thank you,
Pawan
