Getting error
application does not found http://localhost:8080/prweb/PRservlet while trying tp ;login in pega i am getting this error in personal version 7.3 can anyone please help on this
Hi Aniketh,
As per the error screenshot, It seems that you are not able to access the Pega application from the local instance. Please check if the application server has started at your end and able to see the message in the tomcat console as "The server has been started and running".
Hi Aniketh,
Could you confirm the below following
1. Your port number is 8080 in server configuration file.
2. Your server is up and running.
3. Your prweb is successfully deployed and has started (You can check this in manager portal).
hmmm.. mate, what's the web-browser you use? very weird error message in your screenshot =\
