Independent
Independent
Independent
Posted: Sep 13, 2019
Last activity: Sep 16, 2019
Last activity: 16 Sep 2019 7:05 EDT
I have Personal Edition 8.1. How can I run Pega as a multinode environment using Personal Edition?
Hi ,
You can create multiple instance of your application server (Copy paste the instance ), startup and shut down port should be different for all the instances.
Thank You,
Thank you dasn1.
Which exact file should I copy? How can I change the port number?
look for server.xml for tomcat. See the reference (this is from internet, not from pega, but the procedure is the same): https://howtodoinjava.com/tomcat/tomcats-architecture-and-server-xml-configuration-tutorial/
