Design solution for an application which shows data as snapshot but not store them in case
i need some help for design for the below requirement. Pega is a internal application and need to show in screen some entities like bulding details etc... but pega doesn't have this information. This info comes through GET of a Microservice . Pega should store only building id in case and do aget whenever required to show the info in UI. Now question is how to store the information of building ? I have explored several options as below, need some suggestion which might be the best
- Do GET in PRE datatransform of flow action using datapage and copy data to pyworkpage.building and in POSt DT remove the info. [not very much maintainable as new fields introduced have to remove manually]
- Create a building single page in pyWorkPage which refers to datapage which in turn does a GET , later remove the building Info in POST DT [Still data is stored in pyworkpage and needs to be removed manually]
- Create a Top level page Building independent of pyWorkPage and show the buiilding section on this named page in pyWorkpage and later in POST DT remove the top level page. [easy to implement and maintain as whole top level page is removed]
Please suggest which option suits the best.
