Accenture
ID
Last activity: 10 Jul 2019 22:54 EDT
Pega Marketing Segment Error
Hi all,
I've created application over pega marketing framework (Pega 7.4), exploring the function as per user guide and found some problem within it.
1. When i create and try to run segment, the running process never ends.
2. When i try to createsegment and add customer into that segment then check in the change it is working fine. But when i try to edit by checking it out, the customer list dissapear, and i can't discard the change.
3. When i create campaign the context is customer and prospect. But the value in customer dropdown is always empty. I check the source is from D_SubjectDictionary. What should be the value of this datapage since when i check, the activity only obj-open specific class without mentioning any page to contain the value.
4. When segment created, it should create new class with RD for that segment right? here when i create segment (not run yet), the class is not created. I can't found it under PegaMKT-Data-Customer
I attach the image in the docs.
