Atos
Last activity: 16 Aug 2019 12:11 EDT
Native iOS App Login Issue - Operation failed with HTTP status 403.","code":7
Issue:
Upon logging in on the Native iOS app, an error 403 (code 7) occurs.
Logging in a second time, is succesful.
Also:
- Access group - Offline enabled
- Case - Offline enabled
Log file (last lines):
Issue:
Also:
7/9/2019, 8:05:59 PM|INFO|com.pega.hybridclient.bootstrap|JS: Info :: Application 'https://XXX' installation progress: 90%
7/9/2019, 8:06:00 PM|DEBUG||Installation progress changed: 94% for [https://XXX].
7/9/2019, 8:06:00 PM|INFO||Installation failed for [https://XXX] with error [Operation failed with HTTP status 403.].
7/9/2019, 8:06:00 PM|INFO|com.pega.hybridclient.bootstrap|JS: Info :: Application 'https://XXX' installation progress: 94%
7/9/2019, 8:06:00 PM|INFO|com.pega.hybridclient.bootstrap|JS: Info :: Application 'XXX.APP' has changed status from 'installing' to 'failed'. With error : {"description":"Operation failed with HTTP status 403.","code":7}
7/9/2019, 8:06:00 PM|INFO|com.pega.hybridclient.bootstrap|JS: Error :: application installation has failed. Due to : {"description":"Operation failed with HTTP status 403.","code":7}
7/9/2019, 8:06:00 PM|INFO|com.pega.hybridclient.bootstrap|JS: Info :: Synchronization idle - closing account...
7/9/2019, 8:06:00 PM|INFO|com.pega.hybridclient.bootstrap|JS: Info :: AccountManager account will be closed.
7/9/2019, 8:06:00 PM|DEBUG||Unregister subscriber
7/9/2019, 8:06:00 PM|INFO|com.pega.hybridclient.bootstrap|JS: Success :: Logged out 'XXX.USER' user
