Last activity: 29 Jul 2019 2:09 EDT
Application marshalled for different thread issue
Hello Team,
Want to understand why we get the issues like - The application called an interface that was marshalled for diff thread.?
Please find the screenshot attached.
Cognizant Technology Limited
Is your system getting crashed during this issue?
Did you try restarting the server?
The system works perfectly fine and I am not connected to the server. The machine gets restarted almost every day too.
What server you are talking about could you please let me know?
Hello Admin,
I am still facing the same issue, need some #help here.
What is the issue? Are you seeing this when running, or is it just appearing in the log? If it is not affecting the automation at all, then it is benign and can be ignored.
Hello Thomas,
It's appearing on the screen mostly at the start of the project, as I have used a msg dialog as of now for errors. After clicking "ok" to this msg the automation continues the process. I tried suppressing it to from Runtime config file too.
Taran (Tee)
It is likely an adapter exception and benign. You might try suppressing adapter exceptions in the RuntimeConfig, but if that doesn't work or is not desirable, I would suggest opening a support request. Please report the SR number here if you do open one.
Yes Thomas, the thread has been suppressed too, but still the same issue. Here is the SR raised - SR-D26828
