Kafka Data Stream Data Flow Consumes duplicate data when real-time processing dataflow restarts
Hi ,
We are consuming data from kafka topic. Realtime dataflow is configure where kafka stream data set is configured.
While testing i could see when i stop the realtime dataflow and restart it,its processing all the records which its processed before stop.
EX:
kafka topic has 80 records and real time dataflow read all 80 records(for testing logging the data) and now Data flow is stopped.
When i restart the data flow, again it is reading the 80 records which was already processed.
Is there any setup/configuration that should needs to be done at pega so that it will not read data again.
Thanks.
