Error on opening automation
On opening the automation in IDE, I get an error msg: Invalid X value for connection block (see img attached).
If I confirm to open, all blocks have lost their links and many blocks are disappeared.
Clean and rebuild are without error and the project is also deployed correctly.
And the automation within the project working as expected at runtime.
Os file (xml) seems to be formally correct (attached: mainDCMS_Input.os)
Is it possible to restore that automation file? that is to find what is the problem?
Thanks in advance.
