How to generate XML file (not for direct integration)
We have a requirement to generate XML files for manually passing it as an email attachment. So we will not use an integration wizard for this.
Is there a way to do this?
Here is steps I did:
1. Manually create a "XML stream" and map attributes
2. Create an activity with a "Property-Set-XML" method and specify the XML stream I created.
But it dose not somehow run properly and giving me many unknown errors.
IS there any good document or guidance for this?
