"Can not render section" has Error when Call another section
How to make an error massage "Can not render section" appear as text input next to it?
best wishes
best wishes
Can you try to simplify that SECTION in order to identify which element is actually stopping the rendering?
Hi Shiyul,
Looks like you are trying to include a section of another class using some page context. If i am not wrong, there should be no issue rendering it at run time.
Can you try adding that page in pages and classes tab of the section? also check if it is something to do with ruleset validation.
Hope it helps!!
Thanks.
