"Can not render section" in dynamic UI
After completing the exercise in the Dynamic UI lesson, I created a case to test what I had done. When I got to the "Select New Position" step, there was nothing in the UI - no "Position Applied For" field with a dropdown menu, no position details - nothing, just "Submit" and "Cancel" buttons. I opened the section to see what was wrong, and saw the following message under the "SelectNewPosition_Position" section:
"Can not render section SAE-HRServices-Work-Candidate.SelectNewPosition_Position"
There's an existing thread here on this topic, but the answer - that it's not an "error" and that it's supposed to be this way - doesn't make sense to me. Shouldn't I be able to see the UI I just built when I create a new case?
