CNO Financial Group Inc
Last activity: 31 Jul 2019 15:43 EDT
Relationship between data types, data fields, and user views?
I am overthinking and over complicating these in my head. Can someone please break the relationships between these three down into a simple format for me?
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689875000/96a89eee-f2db-4f85-a6aa-6dcf6680da31.jpg?itok=uVg7A4Sn)
Let's consider you as a customer doing some online shopping in my fancy online shop. There are some things I (the online merchant) need to know about you. Namely, who you are and what you want to buy.
As a best practice, I should organize the things I want to know about you into related chunks. For example, you are my Customer and you placed an Order. Those are my types of data.
Now, what, specifically, do I want to know about you as my Customer. For sure your First Name, Last Name, Shipping Address, Billing Address, Contact Information, and whatever else. I also want to capture specifically what item you ordered, how many you want, and how much I am going to charge you. Each of those bits of data is a field.
When you are using my fancy web site, I need to present to you a form to fill out; your view of the data I am collecting about you.
Data type: the name of the container that holds related bits of data (Customer, Order, Billing Address, etc).
Data field: the names of the specific bits of data collected in the data type
User view: the web form (page) used to present the data fields to the user
eddie
shehani Edirisinghe Niranjana Anantha Padmanabhan Caroline Hawes Martina J Sravya Reddy Kesari and 2 More
Thank you Eddie! That was very helpful and exactly what I needed.
Eddie, if I may expand on my question and your example, what about adding in data model, data object, and data page?
You may, but Monday, OK?
Thanks!
Hey Eddie, just wanted to follow up if you have the time I would really appreciate it!
Thank you,
Sorry, I’m late.
In the order in which you would put these things together:
Data model: an abstract, visual representation of elements of data and how they relate to each other. Could be drawn on a white board, a napkin, a PPT slide, etc.
Data type: the implementation of the data model in Pega. Usually organized into containers that hold related elements of data (Customer, Order, Billing Address, etc). Could be in any application, thanks for using Pega :)
Data field: the names of the specific bits of data (elements) collected in the data type. For example, a Customer data type might have the fields First Name, Last Name, Email address, Phone number, Billing address (which is most likely a data type of its own), etc.
Data object: This is so not a term in Pega, but hey - who am I. This term is borrowed (and misused) from OO programming concepts where data + behavior = object. In general, when you see this term used in the context of Pega, it refers to an instance of a data type. For example, we have that Customer data type. Blake is one of my customers, but so is Betty, and Biff, and Irshad, etc. Each of you is a data object.
Data page(s): A visual, human readable representation of all application data stored in cache in Pega.
User view: the web form (page) used to present the data fields to the use.
Sorry, I’m late.
Give me a few days and I will put together a visual.
eddie
Niranjana Anantha Padmanabhan Caroline Hawes Martina J Vinodini Devi Gina Vuu and 4 More
Thank you so much Eddie, I really appreciate you taking the time to help. A visual would be amazing if you have the time!
Shivaji Kadiyam
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689956000/98614b00-8c15-46c1-84ca-1b671f2a965c.png?itok=TQst1Y9V)
I would be grateful for the visual too, Eddie.
And, thank you, Blake, for posting these questions as I'm struggling with the same areas!
I'm glad this is helping someone other than myself! Good luck with learning Pega. It is a lot to learn!
Eddie - I just wanted to let you know I just passed the exam with an 89%! You were a huge help and I really appreciate all of your efforts.
Thanks again!
ROCK ON!!!
We may be on to something here; using the forums as a sort of study group :)
I am just thrilled to read this :) :)
eddie
