Application Style breaks when I save skin rule into a different ruleset
I want to save my skin rule to a different ruleset. Tried both save as and specialize by class or ruleset.
The application is not able to reference the new skin rule, all the styles appear broken in the interface, but as you can see in the screenshot, the app does not even reference Pega default styles, pyEndUSer skin anymore. Even private checkout doesn't work.
I've tried so far:
- Create a new ruleset and save to the highest ruleset
- Save as and create a new skin with a slightly different name
- check that the skin is not saved into an older ruleset
Any ideas where this is coming from? Thank you!
Where it behaves differently between rulesets, the first thing I'd want to confirm is if the ruleset and version you're saving it into are available at runtime. Is the target ruleset in your application stack and the ruleset list for the operator you're testing with?
-Kurt
