Pega 8.1.2 Upgrade, Field Value Error
Upgraded from Pega 7.2 to Pega 8.1.2; tested in Dev; deployed application in Pega 8.1.2 Integration environment; getting the following errors. It appears that conclusion cache is causing the issue. Could anyone had similar issue and appreciate if you could shed some light.
The Field Value with key value(s) @baseclass/pySortType/ASC does not exist
pyStatusCustomerSat: (XXX XXX)ClassKeyValidationFailed-InstanceNotFound Field Value Work-/pyStatusCustomerSat/New
removed dynamic system setting <env name="conclusioncache/fieldvalue/pruneatage" value="7200000" />; restarted. But still the issue exists.
