Launching Modal Dialog automatically
I am looking to launch a Modal Dialog automatically upon loading a screen (an assignment within a screen flow to be more specific). I have tried a couple of different options:
1. Using a js function with a timeout:
pega.u.d.displaySection('{SectionName}', '{StepPage}',null,false);
This works up to a point, after the section loads in a modal dialog the submit button does not work, the submit button is configured with the control pzModalButton and the submit action, strangely enough if I try changing the boolean parameter to true in the function (which is used to hide OOB buttons) the Submit button with the pzModalButton works, but now I have unwanted additional buttons, I tried to look where these are generated but live ui does not work on them.
2. Using the JS API launchLocalAction
var Event = pega.util.Event;
var options = {
flowAction: "{FAName}",
displayMode: "pega.api.ui.constants.MODAL_DIALOG",
event: "onclick",
flowActionClass: "{FAClass}" ,
contextPage: "{StepPage}",
skinFormat: "",
template: "",
isMobileFullScreen: true,
revealEffectName: "",
closingEffectName: "",
closeOnClickAway: true,
centerOverlay: true,
nodename: ""
var options = {
event: "onclick",
skinFormat: "",
template: "",
nodename: ""
pega.api.ui.actions.launchLocalAction(options);
But this generates an error in the console
Uncaught TypeError: Cannot read property 'preventDefault' of undefined
at Object.preventDefault (pzpega_ui_harnesscontext_13405383939!pzevalharnessjson_13618607379.js!clientlogbase_11632504602.js!pzpega_ui_lib_provider_1191955478!pega_yui_12813728239!desktopwrapper_12681084965!developerwrapperapi_12187829019.js!pzsyncappexplorer_11452689760.js!pzautomationscripts_1782107713!pzpega_ui_jquery_1876020879!pega_ui_harness_13108332047!pzpega_ui_harness_actions_11967870250!pzpega_ui_messaging_1861668468!pzpega_ui_jstree_1221119030!pzpega_ui_inspector_bundle_1404366545!!.js:9)
at pega.ui.Doc.processAction (pzpega_ui_harness_deferred_before_11691697527!!.js:29)
at p.c.Actions.processAction (pzpega_ui_harnesscontext_13405383939!pzevalharnessjson_13618607379.js!clientlogbase_11632504602.js!pzpega_ui_lib_provider_1191955478!pega_yui_12813728239!desktopwrapper_12681084965!developerwrapperapi_12187829019.js!pzsyncappexplorer_11452689760.js!pzautomationscripts_1782107713!pzpega_ui_jquery_1876020879!pega_ui_harness_13108332047!pzpega_ui_harness_actions_11967870250!pzpega_ui_messaging_1861668468!pzpega_ui_jstree_1221119030!pzpega_ui_inspector_bundle_1404366545!!.js:2712)
at Object.launchLocalAction (pega_ui_harness_deferred_11024540415!!.js:837)
at myFunction (!TABTHREAD7?pyActivity=ReloadHarness&pzFromFrame=pyWorkPage&pzPrimaryPageName=pyWorkPage&pzTransactionId=3375ad08fe98577757bf710b6945fc23&pzHarnessID=HIDD5BD74FA17FDDC332EB5573BE00B8E3B&PagesToRemove=&PreActivity=RefreshOnConflicts&ActDTPage=pyWorkPage&HarnessMode=ACTION:119)
at HTMLAnchorElement.onclick (!TABTHREAD7?pyActivity=ReloadHarness&pzFromFrame=pyWorkPage&pzPrimaryPageName=pyWorkPage&pzTransactionId=3375ad08fe98577757bf710b6945fc23&pzHarnessID=HIDD5BD74FA17FDDC332EB5573BE00B8E3B&PagesToRemove=&PreActivity=RefreshOnConflicts&ActDTPage=pyWorkPage&HarnessMode=ACTION:73)
The error changes if I change the value of the event parameter, maybe that is what I'm missing, considering that I want to load it automatically, not sure what value to pass.
Can anyone please provide input on how to achieve this requirement? Any input is greatly appreciated
