Non-Stop busy indicator modal dialog launch
Recently our application upgraded from 7.2.1 to 8.1.1. Post upgrade getting non-stop busy indicator on button click - Local action - in modal dialog. Can anyone suggest what might be the cause ?
Pls see the attachment.
Hi Pavan,
Can you check if the harness is rendering in html5 standards? sometimes old modal dialog will try to load when this is not enabled.
You can check portal harness -> advanced tab for document type value.
Hope it helps.
Thanks.
