Canadian Imperial Bank of Commerce
Last activity: 19 Jun 2019 22:41 EDT
exception.PRPCServiceException: org.apache.http.NoHttpResponseException
We are using jenkins to import smart dispute packages to our server. It works fine for small files, However its not working for large files
Error :
com.pega.pegarules.serviceclient.exception.PRPCServiceException: org.apache.http.NoHttpResponseException: XXX:443 failed to respond
Also i tried to get logs from pega, however i did not find any information in logs.
As per your post i have enabled below mentioned loggers.
com.pega.pegarules.integration.engine.internal.util.PRServiceUtils
com.pega.pegarules.integration.engine.internal.ServiceMappingUtils
com.pega.pegarules.integration.engine.internal.connect.rest.RESTClient
com.pega.pegarules.deploy.internal.inventory.SynchronizerImpl
com.pega.pegarules.deploy.internal.loaders.SaverLoader
com.pega.pegarules.deploy.internal.util.ImportImpl
com.pega.pegarules.deploy.internal.archive.ApplicationBundle
com.pega.pegarules.deploy.internal.archive.PegaArchiveImpl
If you are debugging the schema related changes as well the you can enable the below loggers as well:
com.pega.pegarules.data.internal.access.DatabaseSchemaGeneratorImpl
com.pega.pegarules.deploy.internal.util.SchemaImporterTool
com.pega.pegarules.deploy.internal.archive.SchemaArchiveImpl
Please help us with this
Did the request reach the destination server? If yes, can you share the logs there?
Hi Kevin ,
Request is reaching destination server. It starts installing the package also, however if package is large , it will fail the job with below mentioned failures in pega logs.
[ ] [ ] [ ] ( web.impl.HttpUtilities) ERROR - IOException occurred while creating the response outputstreamjava.io.IOException: Broken pipe
org.apache.catalina.connector.ClientAbortException: java.io.IOException: Broken pipe
at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:393)
at org.apache.tomcat.util.buf.ByteChunk.flushBuffer(ByteChunk.java:426)
at org.apache.tomcat.util.buf.ByteChunk.append(ByteChunk.java:339)
at org.apache.catalina.connector.OutputBuffer.writeBytes(OutputBuffer.java:418)
at org.apache.catalina.connector.OutputBuffer.write(OutputBuffer.java:406)
at org.apache.catalina.connector.CoyoteOutputStream.write(CoyoteOutputStream.java:97)
at com.pega.apache.commons.httpclient.methods.multipart.FilePart.sendData(FilePart.java:223)
at com.pega.apache.commons.httpclient.methods.multipart.Part.send(Part.java:312)
at com.pega.apache.commons.httpclient.methods.multipart.Part.sendParts(Part.java:385)
Hi Kevin ,
at com.pega.apache.commons.httpclient.methods.multipart.MultipartRequestEntity.writeRequest(MultipartRequestEntity.java:164)
at com.pega.pegarules.web.impl.HttpUtilities.buildMultipartReponse(HttpUtilities.java:629)
at com.pega.pegarules.web.impl.WebStandardImpl.sendOutput(WebStandardImpl.java:1169)
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:409)
at sun.reflect.GeneratedMethodAccessor75.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:497)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:644)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:725)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:214)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:613)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:142)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:610)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:516)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1103)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:668)
at org.apache.coyote.http11.Http11NioProtocol$Http11ConnectionHandler.process(Http11NioProtocol.java:223)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1520)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1477)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.write0(Native Method)
at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47)
at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93)
at sun.nio.ch.IOUtil.write(IOUtil.java:51)
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:471)
at org.apache.tomcat.util.net.SecureNioChannel.flush(SecureNioChannel.java:140)
at org.apache.tomcat.util.net.SecureNioChannel.write(SecureNioChannel.java:505)
at org.apache.tomcat.util.net.NioBlockingSelector.write(NioBlockingSelector.java:101)
at org.apache.tomcat.util.net.NioSelectorPool.write(NioSelectorPool.java:173)
at org.apache.coyote.http11.InternalNioOutputBuffer.writeToSocket(InternalNioOutputBuffer.java:139)
at org.apache.coyote.http11.InternalNioOutputBuffer.addToBB(InternalNioOutputBuffer.java:197)
at org.apache.coyote.http11.InternalNioOutputBuffer.access$000(InternalNioOutputBuffer.java:41)
at org.apache.coyote.http11.InternalNioOutputBuffer$SocketOutputBuffer.doWrite(InternalNioOutputBuffer.java:320)
at org.apache.coyote.http11.filters.ChunkedOutputFilter.doWrite(ChunkedOutputFilter.java:116)
at org.apache.coyote.http11.AbstractOutputBuffer.doWrite(AbstractOutputBuffer.java:256)
at org.apache.coyote.Response.doWrite(Response.java:503)
at org.apache.catalina.connector.OutputBuffer.realWriteBytes(OutputBuffer.java:388)
Su Zhu
Hi Kuldeep,
If your issue is specific to the large file import with the Jenkins then probably you can go through the below discussion which has so much information to troubleshoot it.
https://collaborate.pega.com/question/unable-import-larger-product-jenkins
Mahesh M
Hi Mahesh,
I have increased the request time out parameter for import job to 600000 , still the jobs are failing for larger files.we also tried using Abort if struck plugin for this. However it also failed to yield any result.
Please help us with Load balancer parameters to be set for increasing the time for time out , as it was mentioned as solution in the link provided in your message.
I am not aware of the load balancer parameters, i think in the other post user resolved it by testing the functionality in the lower environment where he doesn't have the load balancer. May be you can try the same to make sure if its the issue with load balancer configuration.
Hi Team,
We are still facing the issue in importing large file. Any help would be much appreciated.
I would suggest you to raise an SR with the GCS team for further troubleshooting on this issue.
Please reference this URL to this post while creating the SR. Do let us know the SR# once created.
