Does [CIBC-Data-Exception] inherit from [java.util.logging.Logger] or [org.apache.log4j.Category]
Inheritance Level
NameEnter to sort
LabelEnter to sort
Inheritance type
1 | CIBC-Data-Exception | Data table to store Error Codes and Messages |
Both
2 | CIBC-Data- | Class layer for reuse for org data classes |
Pattern
3 | CIBC- | Organization Class for CIBC |
Pattern
4 | Data- | Data- classes |
Pattern
5 | @baseclass | @baseclass |
NA
Inheritance Level
NameEnter to sort
LabelEnter to sort
Inheritance type
Both
Pattern
Pattern
Pattern
NA
Inheritance Level
NameEnter to sort
LabelEnter to sort
Inheritance type
Both
Pattern
Pattern
Pattern
NA
I am trying to use Dynatrace (run-time performance & availability monitoring tool) to monitor Log exceptions from a Pega Application.
Dynatrace has a limitation that in order for log monitoring to work, the monitored application needs to use either the below log4j logger classes to log exception into logs or inherited from these 2 logger classes.
- Java (JDK) Logging – java.util.logging.Logger.log(java.util.logging.LogRecord)
- Log4J – org.apache.log4j.Category.forcedLog
Our Pega Application's exception handling inherits from [CIBC-Data-Exception] --> [Data-] --> [@baseclass]
Can you kindly help to info me whether [@baseclass] inherits from :
or
Thanks very much!
Louis
