NASCO
Last activity: 6 May 2019 14:11 EDT
BIX extract running Slow with PEGA0005 Alert on PR_LOG table
Hi
We are running BIX from command Line and 8 extracts run in parallel.
It was working fine and good a week back but suddenly we are seeing slowness with below alert.
Hi
2019-05-03 09:09:45,564 GMT*8*PEGA0005*803*500*5da4d68558f1ffc3ce98c44314c09676*NA*NA*ACF90C73BC251EF05571F588F357F60CD*ANTHEMNAVBIXUser*Anthem-Claims-NAV-Work*null*04fa9a8c270b65441e60dfa478b8b46d*Y*0*ACF90C73BC251EF05571F588F357F60CD*401*naswaspega04*STANDARD*com.pega.pegarules.data.internal.access.DatabasePreparedStatementImpl*NA*NA*Rule-Obj-Activity:pzLoadAuthenticationPolicies*DATA-ADMIN-OPERATOR-ID UPDATEOPERATORID #20131010T173711.855 GMT Step: 1 Circum: 0******NA*NA*NA*NA*NA*NA*NA*Database batch execution took more than the threshold of 500 ms: 803 ms SQL: MERGE INTO NEWSDATA.pr_log t USING (VALUES (? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ? , ?)) AS inputs ("pzInsKey" , "pxCreateDateTime" , "pxCreateOperator" , "pxCreateOpName" , "pxCreateSystemID" , "pxInsName" , "pxObjClass" , "pxSaveDateTime" , "pyAppContext" , "pyClassName" , "pyFileName" , "pyItemId" , "pyLabel" , "pyMessage" , "pyProperties" , "pyServerName" , "pySystemName" , "pyUserIdentifier" , "pyUserName" , "PYREMOTEADDR" , "PYREMOTEHOST" , "pzPVStream") ON (t.pzInsKey = inputs."pzInsKey") WHEN MATCHED THEN UPDATE SET PXCREATEDATETIME = inputs."pxCreateDateTime" , PXCREATEOPERATOR = inputs."pxCreateOperator" , PXCREATEOPNAME = inputs."pxCreateOpName" , PXCREATESYSTEMID = inputs."pxCreateSystemID" , PXINSNAME = inputs."pxInsName" , PXOBJCLASS = inputs."pxObjClass" , PXSAVEDATETIME = inputs."pxSaveDateTime" , PYAPPCONTEXT = inputs."pyAppContext" , PYCLASSNAME = inputs."pyClassName" , PYFILENAME = inputs."pyFileName" , PYITEMID = inputs."pyItemId" , PYLABEL = inputs."pyLabel" , PYMESSAGE = inputs."pyMessage" , PYPROPERTIES = inputs."pyProperties" , PYSERVERNAME = inputs."pyServerName" , PYSYSTEMNAME = inputs."pySystemName" , PYUSERIDENTIFIER = inputs."pyUserIdentifier" , PYUSERNAME = inputs."pyUserName" , PYREMOTEADDR = inputs.PYREMOTEADDR , PYREMOTEHOST = inputs.PYREMOTEHOST , pzPVStream = inputs."pzPVStream" , pxCommitDateTime = CURRENT_TIMESTAMP WHEN NOT MATCHED THEN INSERT (pzInsKey , pxCommitDateTime , PXCREATEDATETIME , PXCREATEOPERATOR , PXCREATEOPNAME , PXCREATESYSTEMID , PXINSNAME , PXOBJCLASS , PXSAVEDATETIME , PYAPPCONTEXT , PYCLASSNAME , PYFILENAME , PYITEMID , PYLABEL , PYMESSAGE , PYPROPERTIES , PYSERVERNAME , PYSYSTEMNAME , PYUSERIDENTIFIER , PYUSERNAME , PYREMOTEADDR , PYREMOTEHOST , pzPVStream) VALUES (inputs."pzInsKey" , CURRENT_TIMESTAMP , inputs."pxCreateDateTime" , inputs."pxCreateOperator" , inputs."pxCreateOpName" , inputs."pxCreateSystemID" , inputs."pxInsName" , inputs."pxObjClass" , inputs."pxSaveDateTime" , inputs."pyAppContext" , inputs."pyClassName" , inputs."pyFileName" , inputs."pyItemId" , inputs."pyLabel" , inputs."pyMessage" , inputs."pyProperties" , inputs."pyServerName" , inputs."pySystemName" , inputs."pyUserIdentifier" , inputs."pyUserName" , inputs."PYREMOTEADDR" , inputs."PYREMOTEHOST" , inputs."pzPVStream")*
We see only 3000 odd records in the table and it is not big table as well.
please suggest any thing we can do.
