DE
Last activity: 3 Jul 2019 5:33 EDT
Problem installing OCR Component
I installed the Pega Component in a 8.1 Pega Platform environment according to https://community.pega.com/knowledgebase/articles/installing-pega-ocr-component I also installed ABBYY FineReader on the same Pega Platform instance as described in the install guide. When I'm sending a test Email, the attachment is not analyzed, though. In the log file I see that libFRengine.Jni.so is not loaded correctly. Any ideas how to troubleshoot this? 2019-05-06 08:32:23,153 [ EMAIL-Thread-12] [ STANDARD] [ ] [ PegaCSSample:8] (or.Data_AbbyyFineReader.Action) INFO EMAIL.SmartEmailSample.Listener|from([email protected])|sub(new 3)|Email|EmailRoutingForPegaCSSample|Work-Channel-Triage-Email|EMAIL3c1726008fdc499d9382df7effdbee7c|ACVBIB63YIU7PKWP4M9DZLNPF0NJAXTLZA - java.lang.UnsatisfiedLinkError: Can't load library: /opt/ABBYY/FREngine12/Bin/libFREngine.Jni.so
DE
The problem was that I installed the engine in /root/ and thus ran into some accessing issues. When installing to /opt/, it worked.
Does this help
DE
Thanks for the update. We have marked this post as Answered.
Ernst & Young LLP
Hi ,
We have also tried installing the Abby engine for 8.1 in linux under /root/opt/ . Inside pega we have updated the data transform "configureAbbyyFREngine" to refer to the path as in the screen shot attached . we are also getting the error :
Hi ,
DE
I'm not a Linux expert, but when I installed directly into /opt folder, it worked for me. I did not even have to set read/write access, so my suggestion would be that you also try to install it into /opt and not into /root/opt/.
Ernst & Young LLP
HI Thanks for your response .
We have also installed it in /opt and not inside the root folder . Sorry for the confusion earlier . I meant inside the main root folder .Please see the image attached for where the abby is installed under /opt and not inside the root folder . This is still not working for us . Any idea on the owner to whom the access should be granted ?
Yann Philip
