Pega 7.4 Upgrade
Hi
I am upgrading from 7.1.5 to 7.4 and have referred the documentation.
1. What I under stand is in command prompt I have to navigate to the properties files location and edit the properties file and run the .bat file as instructed .. correct?
2. Since I will not have DB write access, can I follow only "Appendix C — Optional: Generating and
applying DDL" and work with DBA? If I do this, nothing else is required?
Pls confirm
