Infosys
Last activity: 11 Mar 2019 5:09 EDT
Inserting a new record into Pega, via a DB script, to create a corresponding Parent case in the background.
We have a requirement of Inserting a new record into Pega, via a DB scripts, to create a corresponding Parent case in the background.
The Pega DB has blob column, is it possible to insert data from other external database via db scripts directly into pega data base and created corresponding cases in the background?
If it's not possible Is there any other way to achieve this requirement?
