Arabic display questions
Implementation detail: Per product feedback, this is the java step that is used to trigger the display of the content:
This works fine in most circumstances, except for the following issue:
- Display the address (PartialAddress), which is a Pega property used in field values, backwards. If the property of address contains the value of “123 Main St”, in Arabic, it would be “Main St 123”. Is there a control that can be applied to disallow this?
- The current CSS flips all content from left to right but it does't make sense for certain situations such as names and address entry (see attached word doc for screenshots) How can the screen retain it's arrangements in content, except just right justified in Arabic?
