Highlight Tab and Menu
I want my tab must highlighting same with menu. If I click other tab, it also must that tab same with menu. Can i get solution.
Amin
Amin
Hi MarcLasserre_GCS,
On the left side is main menu and on the top is tab what we click on menu. So I want that menu highlight same with tab. Likes now on the tab is "Search MI" but on the menu it is still "Support".
Hi Amin,
So why you don't try for that check on the skin if there is an option for some active options or maybe you can create a CSS class that includes that color with a pseudo class. Example:
.example:active {
background-color:#000;
You can try that.
Regards.
Carlos
What's the relation between the menu(on the left side), and the tabs that are getting displayed.
When you click on an option in a menu, so that tab comes up? For Example: if you click on Support in the menu does, the "Support" tab opens up for you?
Correct Rachit_Agarwal. The problem is when user click on the tab it not highlight same things at the menu left side.
Hi Amin,
I believe that this feature is not availabe as of now (May be i am wrong).
The reasons could be , suppose if the menu is a nested menu then how it will be handled and more over if any work object is opened which is not there from any menu then also you will see this behaviour.
I'm not sure to fully understand your need here. So on the screen shot the tab "Search MI" is highlighted and what else do you need?
