- Get Help
Back to top
Back to top
Related content:
Highlight Tab and Menu
Highlight menu on load
Menu Bar hover is not working
On Mouse Hover Menu highlights doesn't work
Accessibility active yellow highlights
Border highlight issue
Highlight Grid
Highlight the row in the workbasket
First row of the repeat grid highlighted automatically
Hello Thommees,
I didn't get a chance to test the below code, but I believe this could be helpful for your use-case.
JS needs to be added:-
// Adds the "ui-state-highlight" class to the selected item. Also
// requires some theme CSS adjustments.
$( "#menu" ).menu({
select: function( e, ui ) {
// Remove the highlight class from any existing items.
$( this ).find( "a.ui-state-highlight" )
.removeClass( "ui-state-highlight" );
ui.item.find( "> a" )
.addClass( "ui-state-highlight ui-corner-all" );
CSS needs to be added:-
/* Global settings */
body {
font-size: 0.8em;
/* jQuery UI theme settings */
.ui-menu .ui-menu-item {
margin: 1px 0;
border: 1px solid transparent;
.ui-menu .ui-menu-item a.ui-state-highlight {
font-weight: normal;
margin: -1px;
/* Demo settings */
#menu {
width: 30%;
Please modify the code/CSS as per your need and test its applicability for your scenario.
Ajit
