Celfocus - Soluções Informáticas Para Telecomunicações SA
PT
Last activity: 15 Feb 2019 11:16 EST
How to reference a field value in data transform?
I've created a property pxDropdown(TypeOfOffer) and the field values "Bundle" and "Others" .
In the section I've created a dropdown where calls the property TypeOfOffer, and one action that run the data transform.
In the data transform I need to pass the field value select, where I can reference the field values in the data transform?
I've tried to set the property to TypeOfOffer in data transform but when I test the field is empty.
Thank you.
