Aaseya IT Services Pvt. Ltd.
Last activity: 21 Mar 2019 12:07 EDT
How do i refer field value from the source field of a data transform
How do i refer field value from the source field of a data transform?
Tekclan solutions
Tata Consultancy Services
Below post is similar to your post.
https://collaborate.pega.com/discussion/there-any-way-reference-field-value-data-transform
This is different actually.
CollabPartnerz
Try to create a field value and use the same in Dt.
I tried , It didn't work.
Tekclan solutions
Prateek Patnaik Naveen Tom
Thanks it worked
Celfocus - Soluções Informáticas Para Telecomunicações SA
PT
I've created a property pxDropdown(TypeOfOffer) and the field values "Bundle" and "Others" .
I've tried to use the function @getLocalizedText(“<Text to Localize>”, ”<FieldValue Property>” , tools), but I don't know what is suposed to put in <Text to Localize> when I have many values in a dropdown list.
Do you know how can I do it?
Thank you.
Débora Almeida
