Is there any way to reference Field value in Data Transform?
New in Pega. Can anyone help? Need to find a way to reference Field Value (pyCaption) from Data Transform.
You should be able to reference it by using .pyCaption.
Sean
Pega Academy Support Team
Thanks for answering. Can you provide an example?
You should save the "field value" with the same name as you reference it in the DT. For example pyCaption "Test"
in the DT you reference the field value with this name. For example
set "Property" -- > "Test" in the design time, the value of the field value will be saved in the Property instead of the name "Test"
