Incessant Technologies Pvt Ltd
Last activity: 25 Jan 2019 2:59 EST
Activity Page is no Loading properly
Activity in our application is not loading properly, Can anyone suggest what can be done to make it normal.
Thanks in advance.
Hi Kalyani,
If the distortion of the user interface is specific to only this particular activity, can you revalidate and save this activity to observe its behavior?
Regards
Mahesh M
We are experiencing the same for all activities in application
This looks an UI renders incorrectly issue. Is there anything shown in the logs for this activity rule?
If revalidate and save on this activity rule does not fix the issue, you may need to clean up cache tables.
Which Pega platform release your application is on?
We haven't find any thing about activities in logs.
And the the application runs of Pega 7.1.7 platform.
Does "revalidate and save" on this activity resolve the issue?
Areantans
can you do trace in time of open any activity. if it's related to UI please check log, you should get something.
Thomas Sasnett
Areantans
also in addition to this did you change in skin rule recently or any hotfix deployment happen?
we dint perform any changes recently, lower environment is working fine.only issue with production.
