Virtusa
Last activity: 24 Dec 2018 1:27 EST
Creating Operator ID dynamically
HI,
Can anyone help me with creating Operator ID automatically whenever the user enters the details such as username and password while registration?
So that with the credentials he entered should become the operator id and password.
FR
Are you talking about the same sort of creation as per this discussion: https://collaborate.pega.com/question/automated-operator-creation-after-ldap-authentication
Virtusa
PL
You didn't specify what type of authentication you are using, but if it's OIDC, then you can take advantage of Operator Provisioning feature which does what you need. It creates operator record for the end-user who logs in for the first time. You can configure how the operator id is created and even specify a model operator which serves as a template for all the newly created ones. Really cool feature.
Virtusa
PL
Take a look at step 2 in this article. It provides screenshot of the Authentication Service configuration section responsible for operator mapping and provisioning. The article is about OIDC (OpenID Connect) authentication, but the same functionality is available for SAML authentication.
Use Data-Admin-.pzCreateOperator activity to create operators
Virtusa
You can call a activity to create or save operator or you can customize pzCreateOperator activity.
Accenture
Pega has a default activity called AddNewOperatorRecord with which we can create new Operator ID and in order to avoid the errors while running the activity , we need to include pyOrganization , pyOrgDiv and pyOrgUnit as parameters and we can set these values with the help of Property Set method in the Activity.
GUNTHA SAKETH RAJAN
Capgemini
NO
Hello Praneeth, Create a section to collect basic details from the user and Call CreateOperator activity on post-processing of the flow action.
Pass following required params to the activity.
Durai Sankar
Ricky Abraham Suggu Kishore Reddy Moumita Dutta Brijesh Vanapalli SRIPATHY M
Virtusa
Thanks Durai Sankar
Virtusa
In the search area type Create-Operator and select the activity with the name as typed and saveas the activity with requires the class name.
Then call the activity in the FlowAction and fill Parameter values.
Now, When the user enters his details operator ID will be created.
AVEEK CHATTERJEE Swetha Nagaraju Ricky Abraham
