Entry for AdminPegaRULES in prconfig.xml
I am trying to deploy R-A-P product using prpcUtils.sh from command line. I am getting the below errors in log:
-init:
[pega:propertyparser] Reading Properties from : /app/GPG/dyn/local/tmp/prpc7_install/scripts/utils/prpcUtils.properties
[pega:propertyparser] pega.jdbc.driver.jar=/app/ora/dbclient/jdbc/lib/ojdbc6.jar
[pega:propertyparser] pega.jdbc.driver.class=oracle.jdbc.OracleDriver
[pega:propertyparser] pega.database.type=oracledate
[pega:propertyparser] pega.jdbc.url=jdbc:oracle:thin:@localhost:24188:PGDBT
[pega:propertyparser] pega.jdbc.username=pgadmin
[pega:propertyparser] pega.jdbc.password=******
[pega:propertyparser] pega.user.username=
[pega:propertyparser] pega.user.password=
[pega:propertyparser] rules.schema.name=prpcrules
[pega:propertyparser] data.schema.name=prpcdata
[pega:propertyparser] pega.agents.enable=true
[pega:propertyparser] column.population.job.mode=COMMANDLINE_JOB
[pega:propertyparser] user.temp.dir=/app/GPG/dyn/local/tmp/prpc7_install/tmp
[pega:propertyparser] import.archive.path=/app/pega7/av/ Proprietary information hidden/0324_all_P3Product.zip
[pega:propertyparser] import.mode=import
[pega:propertyparser] import.existing.instances=skip
[pega:propertyparser] import.nofailonerror=false
[pega:propertyparser] import.commit.count=100
[pega:propertyparser] import.compile.libraries=true
-init:
Here pgadmin is the Admin user(schema) which has both read-write access to prpcrules and prpcdata schemas. Oracle database is used.
[java] 2018-11-28 09:09:37,271 [ main] [ ] [ ] (ernal.access.DataSourceManager) ERROR - Unable to obtain DataSource for sample: j
ava:comp/env/jdbc/PegaRULES
[java] 2018-11-28 09:09:37,274 [ main] [ ] [ ] (ernal.access.DataSourceManager) ERROR - Unable to obtain DataSource for pegadata:
jdbc/PegaRULES
The below entries are there in prconfig.xml that is used by prpcUtils.sh:
<env name="database/databases/PegaRULES/defaultSchema" value="prpcrules" />
<env name="database/databases/PegaDATA/defaultSchema" value="prpcdata" />
Please inform if the below line needs to be included in prconfig.xml to get rid off the above mentioned error "Unable to obtain DataSource"?
<env name="database/databases/AdminPegaRULES/defaultSchema" value="pgadmin" />
What may be the other solution?
