Optum
Last activity: 15 Mar 2016 10:44 EDT
DDS Setting Not being Updated in prconfig.xml
Hello All:
In order to control the Connector Threshold value, that is present in the prlogging.xml file, I have a added a new Dynamic System Setting, as follows:
Owning Ruleset: Pega-Engine
Setting Purpose: prconfig/alerts/connectors/totalRequestTime/threshold
Value: 5000
However, the setting in prlogging.xml is showing as:
Purpose: alerts/connectors/totalrequesttime/threshold
Setting: 100
I am not sure why the setting is showing as 100?
I had to add the setting in DDS, as it was not showing in prconfig.
The default threshold for this setting is 1000. I changed it to 5000, after adding it via a DDS entry.
So, I am not sure why it is showing as 100???
the setting purpose should be: prconfig/alerts/connectors/totalRequestTime/threshold/default
default is the node classification, that is required. Check this link for details: https://pdn.pega.com/how-set-prconfig-values-dynamic-system-setting-value
