AARETE
Last activity: 28 Nov 2018 1:07 EST
How to add row in a repeat grid layout
Helllo All,
I'm not able to add second in a repeating grid layout. Option to add rows are disabled. Is there any way to add rows?
Kishore
Updated: 27 Nov 2018 18:53 EST
You could see pyEditElements section which uses grid repeat layout and has the "Add Item" and "Delete" in its header specified.
Hope it helps!
hi, What version of Pega are you seeing this issue and could you screenshot you grid configuration to further analyze your issue?
Thanks!
Updated: 27 Nov 2018 16:59 EST
AARETE
we are using Pega 7.2.1
Hope it helps!
Synechron
Please share the screenshot with PEGA version details.
Can you try UI Gallery - Repeating row editing on your system? Can you check if row can be added there? You can also view its design-time configuration.
If OOTB can be done, your application cannot, then something is implemented wrongly in your application. You can do a comparison.
AARETE
This issue has been resolved thanks for your help
