Masterdata
RU
Last activity: 22 Jan 2019 11:19 EST
Can't start RDA automation from pega application.
I can't run the automation from a pega application using robot automation on the pre/post processing in the flow action. I've installed Runtime using all recomendations from the installation guide, I've tried to install it as administrator, but all times pega application couldn't start automation. Runtime and solution start up, in application using the correct name of automation. Autometion is started from pega app on the machine whith Studio. As I know, when runtime is executed, localruntime api (https://localruntime.pega.com:9443/api/v1/runtime/isavailable) should be available. On the dev machine it is, but on the end user machine no. What should i do to solve this problem?
Runtime version 8.0 sp1 Studio version 8.0
