VirtusaPolaris
Last activity: 11 Nov 2018 13:27 EST
SSLHandshakeException exception in Connect REST
After marketing upgrade from 7.2.1 to 7.3.1, getting SSLHandshakeException exception on Test Connectivity in connect REST rule.
Unable to connect to resource due to TLS/SSL issue: javax.net.ssl.SSLHandshakeException: com.ibm.jsse2.util.h: PKIX path building failed: java.security.cert.CertPathBuilderException: PKIXCertPathBuilderImpl could not build a valid CertPath.; internal cause is:
java.security.cert.CertPathValidatorException: The certificate issued by CN=AddTrust External CA Root, OU=AddTrust External TTP Network, O=AddTrust AB, C=SE is not trusted; internal cause is:
java.security.cert.CertPathValidatorException: Certificate chaining error
What is causing this issue after upgrade?
